Discuss Heatline Capriz 25 combi in the Central Heating Forum area at PlumbersForums.net
Hi all,
Went out to this one really late in the evening yesterday.
When the boiler is switched on for CH mode, it takes on average 3-4 minutes for it to actually start the process. Once started the flames fully rise and begin to gradually go down and cuts out. From the time it fires up and cutting out its maximum 5 seconds.
On Hw mode, it worked well, until this morning the customer has informed me its doing the same thing as CH mode.
No fault codes have been present before or current. The diverter valve is functioning OK.
According to service manual its pin pointing towards the Gas valve and/or PCB.
Any thoughts on this.?
Regards,
Hary
Appreciate that you have ruled out the diverter valve - but the symptoms you describe are not an uncommon fault.
The diverter valve and the associated gland is normally somewhere in the frame with Capriz problems. If the gland seeps it drips onto the pcb. That can impact the relays - but does not normally write off the pcb. I would be wary of throwing £200 of parts at it.
I just loaded a second hand pcb, unfortunately it wasn't that.
Hary J
Be wary of going too far with this. Heatline can be covered under the Valliant fixed price repair plan - whilst you have done your best to try to resolve it, Heatline are a bit like Volkera - they have a mind of their own and the MI’s are neither well written or ( in my experience ) comprehensive enough to properly fault find
Hary J
Thanks for that. Yes, I did ring their technical the first thing he tells me the model in question is too old for advice over the phone and I need to send an email, where another team will look into it further. What a bunch of idiots! I further told him I do need an imminent response not in 28 working days or something. Just like any other large business these days, are these people even bothered to help.
If I don't get a response by today, I've informed the landlord it needs to come out, as its got various little leaks in places as well. Just couldn't be asked replacing it this current moment of time 😞
Reply to Heatline Capriz 25 combi in the Central Heating Forum area at PlumbersForums.net
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new well maintained Worcester combi boiler. We weren’t convinced the heating was working right and then got hit with a £610 energy bill for the first 6...
MartinPod81
M
I am generally a decent handyman, can usually make 2+2=4 and take care of most things to avoid troubling experts with just the basics, but know also not to bumble around blindly beyond that. We moved house last week and with the glorious hot weather we weren't bothered about the heating, more...
Hi all, Got a nightmare situation with a central heating system I recently adopted. It's an open vent system with a combined F&E pipe, with a Worcester greenstar danesmoor 18/25 oil boiler. Covers 10 radiators mostly large double panels, some towel rails and smaller rads too, as well as an...
2K
We are experiencing an issue with CH short cycling on a Worcester Bosch Greenstar 25i ErP boiler. From a cold start the boiler fires for only ~25 seconds before exceeding the set CH flow temperature and entering it's 3 minute short cycle programme. As soon as the short cycle programme kicks in...
1K
W
Hi all, I've got a bit of a strange issue relating to my Ideal Logic Combi 35 which has recently started displaying a F2 error when trying to use the central heating system. The boiler works fine when using hot water, however when I try to turn on the central heating system the boiler works...
Williams25
W
