Discuss Heatline Vizo 24 fuses in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
kevbis
Hello Guys,
I have had a recent problem with a Heatline Vizo 24 which developed a leak from the diverter valve and as a result started blowing the micro fuses on the PCB.
I have had the leak fixed by uing a repair kit and have also replaced the actuator motor.
The problem is the fuses on the PCB have continued to blow although not as frequently as before.
The fuses I have have used as replacements are 630mA. I am wondering if they are rated too low-I didn't keep the originals so am not sure now what the originals were rated at-does anyone have any idea the correct rated fuses to use or is there another potential fault within the boiler?
Thanks in anticipation
i have the same boiler and mine have 2a qb 20mm 250v fuse i brought a pack of 10 from maplins for £1.99 now just need to find why there blowing.
Reply to Heatline Vizo 24 fuses in the Plumbing Jobs | The Job-board area at PlumbersForums.net
It was fitted with the boiler a Potterton Suprima 30L about 21 years ago. Two PCB's later and a new fan the boiler is working perfectly. However...
1K
T
Please advise me. I am a disabled pensioner. I had a wet room fitted just over a year ago using a local authority grant. Builder was employed by...
TheCatWhoNeedsaHotShower
T
Hello all, I have a WorcesterBosch Greenstar 42CDi classic combi, which is providing DHW fine, but not heating. Was working fine in spring...
1K
Hi, As per the thread title, I have an Ideal Logic Combi 30 and I am having a problem with the pump, which keeps activating without any DHW/DCH...
1K
