Discuss Heatrae Sadia unvented cylinder & Tundish in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All
I have a Heatrae Sadia unvented cylinder... with the usual PVR on the side... which discharges to a tundish which is then connected to a 'fanny trap'.
The problem -
Water trickles through the tundish after about an hour or so of the hot water being heated and the pressure rises. It's only a trickle. To stop this - I have followed the instructions to re-charge the air at the top of the tank. This goes fine - as per instructions. Once air in tank is reset - the tundish trickle stops. Give it about 6 weeks... and its back.
Is this normal - should I have to re-charge the air bubble in the tank every 6 to 8 weeks ?
Thanks,
Tim
You need a G3 engineer without a doubt but the problem is most likely a failed expansion. An external expansion can be fitted of the correct size but only by G3 engineer.
Like people have already explained to you. It’s a very easy fix for a g3 engineer.
There is also a fix for the internal bubble which isn’t always guaranteed to work. We had this issue with some of the new cylinders being stored on there side and developed a remedy for it.
Reply to Heatrae Sadia unvented cylinder & Tundish in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good evening, I'd like your opinion on something that is worrying me please: my landlady's plumber replaced the bottom/night element of my...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
Hi, We have a large Heatrea Sadia unvented hot water tank, not sure of the size in liters but its about 1600mm tall. The tank is around 3 years...
