- Messages
- 8
I am in Norwich, Norfolk - anyone recommend a firm ?Tim try find a local g3 specialist , it may be hard though , where are you based ?
Discuss Heatrae Sadia unvented cylinder & Tundish in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Yes - any they said yesHave you asked them if they’re G3
Hi All
I have a Heatrae Sadia unvented cylinder... with the usual PVR on the side... which discharges to a tundish which is then connected to a 'fanny trap'.
The problem -
Water trickles through the tundish after about an hour or so of the hot water being heated and the pressure rises. It's only a trickle. To stop this - I have followed the instructions to re-charge the air at the top of the tank. This goes fine - as per instructions. Once air in tank is reset - the tundish trickle stops. Give it about 6 weeks... and its back.
Is this normal - should I have to re-charge the air bubble in the tank every 6 to 8 weeks ?
Thanks,
Tim
Thanks for the recommendation...@king of pipes , are you Norwich way mate
Thanks Kings of Pipes... will PM you.Yes mate I am Norwich way i can take a look if you're getting nowhere Tim pm me cheers tkop
Reply to Heatrae Sadia unvented cylinder & Tundish in the Plumbing Jobs | The Job-board area at PlumbersForums.net
