Discuss Heimier Remote TRV: As rare as hens teeth, or am I looking in the wrong places? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
Harlequin
I have an underfloor water heating system. A Heimier remote TRV is located close to the heating manifold, in order to regulate the temperature of the water flowing through the system.
I now need to replace the TRV - just the thermostatic screw on 'head' (if they come separately), complete with wire to link to the remote sensor.
Questions: 1) Any one know where I can source one of these Heimier remote TRVs (I live in SW London). It's proving tricky to find one. 2) As an alternative, are there any other brands of remote TRV that have thermostatic heads that will fit the Heimier male screw fitting on the metal valve?
All responses much appreciated.
Thanks.
Uponor use a remote trv on some of their underfloor heating manifolds.
Thanks for the responses so far. Have had a tip that Pipe Centre may stock them, so off to check. Will also check the website.
Reply to Heimier Remote TRV: As rare as hens teeth, or am I looking in the wrong places? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper...
Hi All! Bought a house recently, and we have been having the most frustrating issue with a very loud humming noise that intermittently comes and...
2K
We live in a 1980s four-bedroom detached house. The time has come for new central heating. The current system is a mild revision of the original...
2K
Hi, A bit of background first I have a air source heat pump, downstairs is all underfloor heating and controlled by individual room thermostats...
2K
