Discuss hello all not a plumber but hoping for a bit of advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Richard40
Ok here I go ,I need a new combi and was going to get a bosch fitted 6 rad s in two bed terrace,any how plumber I have gone back two as he did some work before has said the ideal mini l 30 is a good boiler and he fits these and bosch ,we have an ideal is at which we inherited it ,it now gives us warm rad s when switched off so I thought I'd go bosch but I trust this bloke but I'm a bit wary of ideal ,any advice appreciated !
Hi Richard and welcome to the forum,
Each engineer on this forum will give you a different opinion as each have there own experiences good and bad with brands, if you are keen on Bosch then the cdi Classic (5) is good, don't go for the I range or the junior (2), ideals are good either logic plus (7year) or the vogue,(10).
the numbers I've put in are the warranties issued with the product,
also vaillant , Baxi ,
I'm not a fan of Ideals; they've cocked up too much in the past.
Vaillant or Worcester CDi Classic (NOT compact) would be my recommendation.
I find it odd that you have set aside a budget for a worcester ( they are not cheap) and your installer recommends ideal mini which mostly get fitted on tight budgets or landlord properties.
I would question his / hers thinking their
Hi I could of got mixed up as I looked on plumb centre he could have ment the indecent as he said it was the same as a logic in side ,any how I've measured the boiler cupboard and it looks like it down to the logic logic +is there much difference?,or Worcester cdi 30 compact but some one said stay away from ,not checked back but if there ok I'm not against ,only had bosch in mind because a few people have had them and said they were pleased with them.I'm getting my price off mr central heating had a price off a thousand in mind for the boiler but a bit more or less
Richard, you could try uk-plumbing.com for a price comparison, I buy my spares there and always good service.
Reply to hello all not a plumber but hoping for a bit of advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Looking for advice please, our plumber has left us in it and I think I may know why. So they where supposed to be fitting a cloakroom sink...
F
Hi, We have a new Ideal Logic Combi 30. A radiator today came off the wall and developed a leak. Plumber came and fixed (but didn't). At that...
FrankMcg
F
Hi all, new to this forum and looking for a bit of advice please. Have been noticing recently some odd behaviour with our hot water system. If...
Hello, We had an extension built seven years ago. Initially the builders' plumber connected the heating to the house system but this didn't work...
