Discuss Help 20 rad system top ones not getting hot in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Super Mario
Ive flushed the system but the top 2 wont get hot not even legs i sucked it through return with wet vac and it was roasting but now gone cold again tried balancing but no joy system is clean no air lock bled alk rada and pumped with mains anyone know? Cheers
Should be a 25-80 pump if sealed
Have you installed the system, has it worked properly previously
i would say definately not big enough 25/80 should kill it but need to make sure it doesnt pump over
Reply to Help 20 rad system top ones not getting hot in the Plumbing Jobs | The Job-board area at PlumbersForums.net
