Discuss help identify this bath tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
erion
have been asked to fix the tap cant identify it and customer has no details about it.
Pop centre caps off, undo screw and remove the tap head to reveal the part you want to get at?
I would go down the route of new tap
was looking to replace the whole thing but as its massive i thought i could do like for like
Measure from centre of one tap to the other this will help you see what is available to replace it with.
Reply to help identify this bath tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes sunk into wall behind bath. Walls have fresh tiles. Have realised as about to fit shower these pipes one is set higher than the other. If you fit a...
