Discuss Help: Intergas Boiler: Has my filling loop been installed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I think I have the same problem as you and wonder if you can help. we have just moved into a flat with the same boiler and I can't find a filling loop. Pressure has dropped to 0.4 although can't find any leaks. But the missing filling loop is driving me insane. I can't access your photos. I am attaching mine. Can anyone help??Thank you All. Have followed advice re the filling loop and everything now seems to be charging up. Phew! Many thanks again.
Hi. Do you also have a tank? If so - try there (it’s where I found mine). Else, as someone advised me, you might well find it in a “nearby cupboard”. The clue should be the metal flexible ridged piping with a pressure meter nearby.I think I have the same problem as you and wonder if you can help. we have just moved into a flat with the same boiler and I can't find a filling loop. Pressure has dropped to 0.4 although can't find any leaks. But the missing filling loop is driving me insane. I can't access your photos. I am attaching mine. Can anyone help??
Like this? Is this the filling loop do you think? (found by the cylinder).
Thanks.
Thankyou so much for getting back to me Steve. And so quickly! I found it!! Miles away in a cupboard where there used to be a tank. Phew.Hi. Do you also have a tank? If so - try there (it’s where I found mine). Else, as someone advised me, you might well find it in a “nearby cupboard”. The clue should be the metal flexible ridged piping with a pressure meter nearby.
All the best, Steve.
Reply to Help: Intergas Boiler: Has my filling loop been installed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
