Discuss Help locate a shower valve key 34mm diameter with 2 prongs, thanks in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi Group,
Im trying to remove a thermostatic cartridge and Im struggling to find a key to remove the valve. The diameter is 34mm and there are two prongs needed to fit into the valve retaining nut
Help greatly appreciated
thanks
Presumably the plate and maybe a shroud will come off easily enough.
I then usually use an old large flat bladed screwdriver and drive it around with short sharp taps of a hammer.
If that fails , cut yourself a ‘key’ using a grinder and a bit of steel plate.
To be honest the screwdriver has always worked for me.
Hi Group,
thanks
It's the distance between the 'prongs' that is needed, which I estimate to be about 25mm from the photo.
I'm aware of this tool, but seems to be out of stock - sorry, not much help!
This sounds like a bodge, but I've had success in the past using long nose pliers and a parallel jaw large wrench applied near the 'nose' to turn them!
And as Ben jee just mentioned, tapping with a screwdriver, so I feel my method is not such a bodge after all!
A bit of appropriately sized tube and a hacksaw is the other approach 😀
As Ben-Gee has stated the chrome face plate should pull forward, then the chrome round shroud leaving you with access to the cartridge. Either a large spanner or flat blade screw driver to shuffle it round. If you need a new one try Shower Doctor online with a photo of the existing one if you don't already have one.
Reply to Help locate a shower valve key 34mm diameter with 2 prongs, thanks in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
I have a green star ten yrs old keeps increasing pressure, feel on off filling valve not working, drain off to recommended, but after few days...
