M
Discuss Help me identify this 15mm elbow fitting in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Looks like a specalist fitting. Probably supplied with the shower itself!
You may be able to reconnect with some pipework alterations...
Why do u need to change it? If it's leaking from by the spinning nut, get a 4 mm( guess) Alan key and in do center of spiny nut. Apply locktight jobs done.
second photo shows its cracked ermi
op, which side needs to connect to the shower ?
boom, things looks like the same product
[DLMURL]https://www.divapor.com/spares/showers/fixtures-fittings/male-female-elbow-fixing-connector.php[/DLMURL]
Reply to Help me identify this 15mm elbow fitting in the Plumbing Jobs | The Job-board area at PlumbersForums.net
