Discuss Help me understand the specifications of an UFH mixing group in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello everyone,
I have installed in my house an UFH system that consists of:
  • Condensing boiler
  • Hydraulic separator 4.5m3/hr
  • UFH mixing group - TECEfloor – 7745 00 00
  • Manifold TECEfloor – 7731 00 xx
The circuits are laid as follows:
Zone 1
  • 3 circuits 80m each
  • 10 cm spacing
Zone 2
  • 1 circuit 85m
  • 1 circuit 96m
  • 10 cm spacing
Zone 3
  • 1 circuit 100m
  • 10 cm spacing
Zone 4
  • 1 circuit 52m
  • 5 cm spacing
I need your help to figure out how to setup the mixing valve and balancing valve. Right now it is set to 35°C with a 1500l/h set to the balancing valve. I don't know it this is right...
Can someone explain how to find out the optimum adjustments?
Also, is there any way i can find out the pressure drop of the UFH mixing group and distributor? I don't know how to interpret the Thermostat Kvs value and the Return valve Kvs value.
Below are the technical details of the Mixing and pumping unit.
Operating modes:
  • Constant pressure 300 mbar <-- pump is set to this
  • Constant pressure 400 mbar
  • Proportional and
  • Variably adjustable
Output approx. 10 kW,
Primary flow max. 90 °C, primary return max. 55 °C,
Pmax = 6 bar,
Thermostat valve Kvs value 4.0,
Return valve Kvs value 2.7
Many thanks!
Is it possible to give me further details?
I am seeing that the balance valve can be set to a different value meaning different flow rates.
I don't understand how it balances itself.
Thank you!
Reply to Help me understand the specifications of an UFH mixing group in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Do people with this type of mixed flow temperature control have any problems with achieving the required manifold flow temperature? The one below...
Hi, I have a combi boiler that supplies hot water to two ufh manifolds. We only have ufh and no radiators. I am trying to find the most efficient...
1K
Hi Guys Im after any advice or if someone can recommend a good heating engineer in Thanet ?. I had a Wundafloor manifold installed for our...
2K
hi All, can someone help me clarify following issue? is there possibility when room stat calls for heat (UFH system), it opens the zone valve...
1K
Hi, I've installed a 2 zone kit that uses an RWC mixing valve, Thermomix with hot in, return to boiler and heat out to Ufh pump and return from...
11K
