Discuss Help on connecting channel drainage to soil pipe in the USA area at PlumbersForums.net
Hi, I'm installing a patio across all of my back garden, and was intending to put channel drainage along the cream wall shown in the picture. I've recently had some pvc soil pipes put in, shown in the picture, so my thought was to connect to these (they already take rainwater as it's an old property).
I'm not sure the best method for connecting - the existing pipe bits seem pretty solidly put together (I don't know if push or glued). I've looked at boss connectors but these seem more aimed at internal /above ground pipework and don't go any larger than 40mm.
Advice would be greatly appreciated. Pictures for context.
Sam
Putting more storm water into the foul drains might be a bad move one day ?
Have you considered if a soakaway might be possible somewhere (need to keep away from walls). Presumably at the moment the rain just soaks into the ground.
Is the courtyard surrounded by walls on all sides ? ( and are they house or garden walls etc.)
Cheers,
Roy (very amateur plumber )
Hi Roy,
Thanks for the response.
I've been looking into that, but I understand a soakaway needs to be 5m from the house. The garden simply isn't big enough for that. Three of the walls are garden walls, the rest are the house.
Do let me know if you have suggestions though.
Sam
Reply to Help on connecting channel drainage to soil pipe in the USA area at PlumbersForums.net
Hi, I have an opening on the 'manifold' (I think that's what its called) on my soil pipe. It appears to be a non-standard size - about 51mm...
Hi I'm in process of completing a loft conversion and need some advice on the location of a boss adapter for the shower waste. Can a boss...
1K
Deleted member 120897
G
Hy all, So i noticed the corner in the living room was getting damp. investigation showed that the corner skirting board that goes around the...
1K
Hi, we have moved our upstairs bathroom so need to put a new soil stack on the outside wall. In the place where we want to put it is a rainwater...
3K
Hi I need to connect a kitchen sink to a soil stack but the soil stack has an inspection hatch and what looks like a reducer into a clay pipe...
3K
