Discuss HELP PLEASE – Plug mechanism is broken in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
Howdoi?
I could do with some advice please.
My bath has an overflowand plug, which lifts when you turn a handle.
Not particularly unusual, I know.
The handle has stopped twisting, meaning I can’t lift theplug. For a long time the handle didn’t lower the plug (I just pushed it down)but now it won’t go up either.
I’ve unscrewed and removed the handle and tried to turn thebar that the handle turns, but it only rotates about an 8[SUP]th[/SUP] of afull circle. I have tried a bit of force but it won’t go any further. I couldgive it a fair bit of force, but might break it!
Do any of you have any ideas what has gone wrong? Any suggestions?Should I take the overflow off? Should I check the cable? If do how? So manyquestions.
Cheers,
Dave
cables corroded or broke.
there £25 upwards.
if you like to fiddle then you can strip and replace with abike brake cable for a couple of quid
http://www.NoLinkingToThis/p/pop-up-bath-waste/27022
You need to shop at Screwfix Red, £15 not worth the mucking about.
Thanks guys. Oh no, I definitely don't like to fiddle. I'll happily get a new one! Just wanted to check that I didn't do something unnecessary.
One follow up question - is it likely that I'll have to replace the plug too? Or can I get away with just replacing the cable and overflow bit? I could do without ripping out the actual plug if I can help it.
most likely you will have to change the whole unit top and bottom parts as one
Reply to HELP PLEASE – Plug mechanism is broken in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I know nothing about plumbing 🤦‍♂️ and am trying to sort out a leaking kitchen tap. It's a Franke Davos 'J' Tap. I turned off the water to the...
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
Dear All New member here, coming looking for help. A few weeks ago I had work carried out by a British Gas Homecare service technician. It...
Hello all, first time poster so if there is any additional information I can provide that may help, please let me know. Our kitchen mixer tap has...
Hi all, please could anyone help me with the following issue im having. I will start off with listing the scenario in case it helps. Boiler -...
1K
