Discuss Help - radiator valves wont disconnect from pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello there,
Need a bit of advice please! I am trying to remove two radiator valves in my bathroom as I have bought straight ones for my new towel rail. I have drained the system however the problem is I can't get the two valves off! I can turn them easily with a wrench and have turned them hundreds of times but they wont disconnect from the pipe. Any ideas? A bit hesitant to get a plumber out for a 2 minute job. Thanks in advance.
Link for image: Imgur: The most awesome images on the Internet
http://*********/a/yYHss
The pic is an ISO valve ??
And tbh might be best you call a plumber out unless the system is already drained
Yes thats correct - is it difficult to remove? I have drained the system already
Undo the bottom nut and should come off easily
May need a twist of the main body (valve) but should come off
It doesn't come off! It turns easily just wont come off. should i use 2 wrenches - one to hold the bottom nut still and one to turn the valve? Was worried i would break the pipe doing this.
Yes you need to do that
You will understand if you remove the top nut
It's not push fit it's a compression fitting
I see, feel so stupid now. Thank you!
Since you didn't know how to dismantle a compression joint I suspect you won't know how to assemble one correctly either. Google 'copper compression joints' for many websites explaining how to do it. Read several. Here's an some fairly detailed information:
Compression fitting - DIYWiki
And I'm expecting ShaunCorb to recommend another below. He didn't like my original suggestion, possibly because it used sealant on the thread rather than a lubricant such as ptfe tape.
Check the finished joints very carefully for leaks. Then check again in a day or so.
Don't forget to put the correct amount and type of corrosion inhibitor back into the system when you refill it.
Since you didn't know how to dismantle a compression joint I suspect you won't know how to assemble one correctly either. Google 'copper compression joints' for many websites explaining how to do it. Read several. Here's an example:
http://www.diydoctor.org.uk/projects/copper_compression_joints.htm
I wouldn't use that link as a reference
  • Agree
Reactions: rpm
Okay, I've replaced that one with what I think is a better one, but it may be overkill as far as detail is concerned. Is there a site you would recommend?
It seems a bit strange that ukplumbersforums doesn't have it's own set of 'how to' guides for basic tasks. Is this policy, or has nobody got around to it yet?
Thank you so much for the info, will give them a read! I have another query however. I have just turned on the heating and the boiler made some loud bangs so I hurriedly switched off the heating. Any reason for the cause? There is one valve in the loft that i have left closed after draining the system, and that's because it has started leaking. The valve didn't turn off the water from the tap so I'm guessing that it is linked to the boiler somehow?
did you fill the system back up?
That just involves turning the stopcock and valves open right? Or is there more to it!
Just been back up to the loft and the valve seems to have stopped leaking now so its open again. When I turned it, the container housing the ball float filled up with water.
Loud bangs from a boiler are not a good sign. I recommend that you don't switch it on again until it's been checked by a Gas Safe Registered engineer.
The good news is that they'll be able to sort out your valve problems at the same time. :)
Reply to Help - radiator valves wont disconnect from pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes a squeak noise as I turn it on or off, left tap is 100% perfect and noiseless. This grohe tap is like one unit, so no screw notch or way I can remove...
