Discuss Help!? Replacing Old Sunvic stat w Nest Learning Thermostat 3rd Gen - Heat only system in the Central Heating Forum area at PlumbersForums.net
Evening all,
Apologies if this has been covered in another thread - I've never called upon a forum before! 😬
We're in the process of upgrading our old heat only boiler with a new Ideal Logic heat only boiler.
So, feels like an opportune time to upgrade our ancient (albeit reliable) Sunvic thermostat with an up to date smart thermostat - the Nest Learning 3rd Gen..
I've checked online for compatibility and it's not all that conclusive 🤷‍♂️ We've got solid core copper cables feeding the old stat, so that appears to be a tick, but I just want confidence that it will work with my system - words of confidence (or not) would be greatly appreciated!
I attach pics of our existing system and stat, and cables feeding it 👍
Good morning Krissyboy,
I don’t see a reason why it wouldn’t work. You have a y-plan system, the thermostat would need the 2 wires joining to the nest thermostat or disconnecting in the wiring center if you intend to use a usb lead for the nest thermostat? the heatlink would go where that black programmer is situated in the cylinder cupboard and wiring appears accessible. Should be straightforward enough.
Aquarius - season's greetings and thank you, that is really helpful!
I have just watched a video on wiring up the Nest to a "y-plan" system and now makes complete sense, lots of familiar parts etc! I am now satisfied that I can proceed to order the device.
Wishing you and yours a great Christmas!
Kris
Reply to Help!? Replacing Old Sunvic stat w Nest Learning Thermostat 3rd Gen - Heat only system in the Central Heating Forum area at PlumbersForums.net
PSxxxxxx
