Discuss Help required for replacing union valves. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello,
New here.
I have some older type single radiators in my home, that I want to keep.
The are supplied by 15mm copper pipe, into the valve, that has a 3/4 union type fitting.
I want to replace these fittings with TRV's and am having difficulties finding a direct replacement.
My floors are concrete, so I don't want to replace the rads with 15mm compression valves, as I believe I would need to alter the pipework.
Any of you guys have ideas?
Thanks in advance.
PS, I'm not a plumber!!!!!!!!!!!!!
You won’t get any 3/4 union trvs so will need to adjust the pipework
Could you (stupid but it may work) put a straight TRV onto the pipework feeding the radiator without removing the existing valve? Might be a possible workaround if you can get the TRV into a position that is useable and don't mind it looking slightly unconventional (what WILL the neighbours think?!).
Reply to Help required for replacing union valves. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it is earthed. The new tap will use flexible tails and so will not be earth bonded. My initial search for information suggests that there is no legal...
