HELP! Tub stopper stuck in closed position
View the thread, titled "HELP! Tub stopper stuck in closed position" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I accidentally jammed the tub stopper and it won't come out, instead of using the level I just pushed it down... Is there any way to fix this without taking all the system apart? Or Do I also just need to get a new waste system for the tub?
Any chance for you to post a photo?
Wet vac the water out of the bath if full then remove the trap from under the bath you can then push the pop up waste from below . cheers kop
Reply to the thread, titled "HELP! Tub stopper stuck in closed position" which is posted in UK Plumbers Forums on Plumbers Forums.
mplaza,
William Norman,
