Discuss HELP! Tub stopper stuck in closed position in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I accidentally jammed the tub stopper and it won't come out, instead of using the level I just pushed it down... Is there any way to fix this without taking all the system apart? Or Do I also just need to get a new waste system for the tub?
Try a rubber sucker, like the end of a child's toy arrow or similar. Pull gently on the sucker while pushing the lever down.
I tried that already and didn't work , I believe because it was kinda of screw type it wont come out that way
Ha ha use a wet and dry vac to get the water out first.
Any chance for you to post a photo?
Wet vac the water out of the bath if full then remove the trap from under the bath you can then push the pop up waste from below . cheers kop
Reply to HELP! Tub stopper stuck in closed position in the Plumbing Jobs | The Job-board area at PlumbersForums.net
