Discuss Help with AAV locations and importance in new bathroom fit in the USA area at PlumbersForums.net
Stephen44uk
Hoping for some advice on the use of AAVs while plumbing in my new bathroom. There is a sketch of the waste layout in the link below. All of the plumbing is concealed within floorboards or stud walls, so I can't have any AAV's on show. There are 2 voids either side of the bathroom and an AAV at highest point on the 110mm.
However all the 40mm horizontal runs from basin, bath and shower are all over 3m each. Researching I have found AAV's or anti syphon traps need to be used. These traps are no good as shower and bath trap are too low in floor and basin uses a decorative bottle trap which matches rest of items.
Are they that important, as I do not want smells or gargling from the new bathroom. The only place I could fit an AAV for the shower and bath is to Tee off both runs and place one within a false stud wall and remove insulation so it has space around it. Its not ideal but would this work and be better than not using 1 at all? Is there a distance it needs to be within the traps?
Likewise the basin would need waste pipe routing through stud walls to reach a decent void, it can be done but a lot of work, is it worth it?
Any advice other than get a plumber will be greatly appreciated.
Thank you
Link to the sketch plan:
Reply to Help with AAV locations and importance in new bathroom fit in the USA area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes...
