Discuss Hep 2o imperial in the Plumbing Jobs | The Job-board area at PlumbersForums.net
anz
Does anyone know if you can use 15mm hep fittings on old 1/2 inch copper pipe?
Or is there an adapter available?
I can't say for sure & I don't use plastic, except to connect onto existing plastic or replace leaking fittings, but I think 1/2" pipe should be fine on plastic fittings as it is almost identical and just slightly larger, so gripper & O ring will be tight.
The plastic fittings are a loose fit on the pipe and it is only the gripper & O ring that are tight, so I can't see a problem, but better to look what Hepworth produce
most manufacturers make fittings for said purpose, tho if its thin wall it should be the same size or near as dam it. easiest way is to just convert with an end feed or comp coupler.
Reply to Hep 2o imperial in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, does anyone know why the water only fills 1/3 of the way please?
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes...
Does anyone know a good, not super expensive, leak detection company in the London area?
