Discuss HETAS registered in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dannyparty92
Do you have to be HETAS registered to fit wood burning stoves?
i would say yes but i'm not an expert. one will be along soon.
no, but you cant self cert without the qualifications and a registration to a competent persons scheme. you would have to pay building control to come out and inspect your work and sign it off.
without good knowledge simple mistakes can happen, like a flue liner not fitted the right way up, wrong clearances, ventilation, etc....... so if you do fit without being qualified/registered do your studying well and get it right.
basically as aw said the answers no but it does require knowledge and building control coming out to pass your work,dont take this on if your unsure danny more people die from solid fuel fits than gas
Part j of the building regs is a good start point if your looking into whats involved. the area you live/your customer lives in can effect what you can fit also as regards smoke restrictions.
Reply to HETAS registered in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form to fill in what do u need to sign off in england as building control said they dont give out forms like they do in northern ireland
