Discuss Hi, anyone know what this is? Image attached in the USA area at PlumbersForums.net
Hi, does anyone know what the image is below?
would say something like flue gas heat recovery
Now this is a bit of wild guess but it could well be a drain waste heat recovery unit. For preheating incoming water to cylinders. It has two connections that look like they'd take the water you want to preheat through it and a connection big enough for a waste pipe too. The only problem is that the outlet looks too small for that purpose?
Whatever system it's supposed to go on to it is surely some kind of heat exchanger/heat recovery device.
Edited, not Heat exchanger but, Commercial boiler possibly Potterton, condensate collector (heat recovery)
Most likely Item no 9, Potterton Paramount,
Reply to Hi, anyone know what this is? Image attached in the USA area at PlumbersForums.net
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Does anyone know a good, not super expensive, leak detection company in the London area?
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
