Discuss Hi I have a worchester heat slave 18/25 and continually needs bleeding in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi I have a worchester heat slave 18/25 and continually needs bleeding of the Kero, runs all day when bled. when it cuts out on the stat it wont start again without bleeding
Is the tank higher than the oil pump?, what is the oil level?
Is it a one pipe system with the blanking bypass screw installed/ or a 2 pipe or a tiger loop?.
Has the flexible hose been replaced fairly recently?.
Reply to Hi I have a worchester heat slave 18/25 and continually needs bleeding in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
