Discuss High Flow Double Check Valves in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Marc Bowers
Hi all, I’ve a customer with a failed double check valve on a water softener, it’s 22mm compression but with a far larger bore than the usual DCV’s you see online. Anyone know if they are called something different or where I can get one? I’ve even been on the water softener website and they don’t seem to sell them. Ta.
You sure it’s not a 28mm dcv threaded end eg 1”-22mm male irons
That’s what I normally do
Another option is a swing check valve have to be installed horizontally tho
Is it the attached per chance?
Dear Marc, how did you identify the failed double check valve on a water softener? The inlet to our Harvey's softener has been making a clunking noise intermittently for 5 days now. Could it be the same problem as yours? Thanks so much for reply Sara
My problem was flow rate. A clunking noise is usually water hammer and can have a number of sources (not necessarily in the area of the noise)
Reply to High Flow Double Check Valves in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
R
I just had installed a Navien NPE-2 with built in recirculator pump. I have a dedicated return line. The check valve for the recirc is built into...
Rogelio
R
Hi Fitted a new out the box’s boiler today. It worked for 30 minutes. Then stoped and went to fault codes 2965 B Flow temperature too high ▶...
Hi everyone, I'm a (somewhat, I hope...) competent DIYer and just want to get some advice if my suspicion on a problem we're having is correct...
Hi everyone, I moved into a new build three bedroom, two bathroom bungalow about 2.5 years ago. Ever since we moved in there has been an issue...
6K
I'm after some guidance if possible please. I have a fortic F1 vented direct cylinder with an instant immersion and an economy 7 immersion. A...
DevishaM
