Discuss Hints, tips & secrets of plumbing - No Banter please! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
When applying silicone along a bath, basin etc i always spray with windolene before smoothing, this stops any smearing up the tiles and bath and gives a great finish.
13mm ratchet spanner on tail key. View attachment 11770
mine goes red whatever i try to do!!! i always use mapp gas with it, the bernzomatic tip doesent get red or hot tho!
when you fit a bath dont use the L shaped brackets there useless and you will get alot of movement from the bath, instead level the bath put a pencil line around the top of the bath ease the bath out of place and apply PINK GRIP adhesive about 10mm below your line, use plenty of it then throw your bath in place, give it a good wiggle to ensure it grips, if any goes on the bath dont rub it off, let it cure an it will just break off in go, (same goes for expanding foam if it gets on your hands dont rub it, let it cure an peal off in one go)
Reply to Hints, tips & secrets of plumbing - No Banter please! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
