Discuss Hints, tips & secrets of plumbing - No Banter please! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Easier to cap off cold feed and put wet vac on outlet. Cylinder will implode and the insulation will fall off.
when fitting rads under a window sill measure down from the sill for top of bracket height fix brackets pop rad in place check levels and whichever side is the high spot pop the bleed valve on . I go to quite a few complaints (not my jobs) that are rads that seem un level when infact its spot on but they look out because of the sills
I'd speak to customer first. "Do you want rad level or parallel to windowsill?"
With some people no matter what you do they will find a problem.
fair play I just do it as a standard only ever had one customer follow me round with a level and they didn't find one level rad of mine all the ones under the window sill were perfectly parallel and every other rad I fit I send a level line across fit brackets check for level and if they are spot on I send a tiny tap to one of the brackets I was always taught to have a slight un level on rads up to the bleed nipple and as I think its make perfect cense that's how I fit them ime not talking much but over sat a 1200 level 2 milly is in my eyes perfect
note to self: when reconnecting appliances in property where council have been in and decommisioned it, check EVERY connection on every appliance including supply! numbnuts had loosened the supply to the meter put new olive in and just turned nut slightly ... i got wet
install slam locks on van. very handy and very good, saves having to use keys if you are struggling with anything heavy and time wondering if you've locked it or not ... just remember to check you have keys in pocket before you slam though :)
When change a immersion heater , make sure you remove old gasket and clean the sitting with Stanley blade and then install the new immersion heater
If every using anybody else's electric appliances or set ups, in my case my uncles set up for the light in his loft......
Just have a quick check for obvious defects or potential problems.
I got a belt from a horrific DIY job where my uncle had wired a plug on both ends of a flex to power the light in the loft.
I didn't check this and when I unplugged one end, it was still live as other end was plugged in and it hurt!!
ч
Tell uncle never to play with electrics like this ..... Is this even allowed !?
ч
No way is it allowed. It's like allowing a plug with a flex and 3 exposed wires. Pins on the plug are just the same when the other side is live
To aid adding inhibitor, leak sealer or cleaner ect Make one of these up, keep compression fitting loose as then u can keep filler upright and tighten into rad. Take blanking plug out of other side as it avoids gurgling.
Solder a bit of 15mm into a 1/2 to 3/4 rad stump. Attach to hose. Draining down via a rad or makes syphoning easier. If rads are 15mm tail type just attach 3/4 valve and use 15mm connection.
I have a drain of hose exactly the same as that one great if theres no drain off hopefully snatch a small radiator and drain away
for inhibitor i use half an auto air vent and bent male iron with o ring, and the very same make up for draining with no drain off. good call.
Reply to Hints, tips & secrets of plumbing - No Banter please! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
