T
tamz
Strip the test nipples off old boilers and throw them in the van for spares.. Profiles, some ideals and gw's etc
Discuss Hints, tips & secrets of plumbing - No Banter please! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
For guitar players, a short length of chrome plated 22mm makes an excellent slide!
To aid adding inhibitor, leak sealer or cleaner ect Make one of these up, keep compression fitting loose as then u can keep filler upright and tighten into rad. Take blanking plug out of other side as it avoids gurgling.
yes of course if it has one that's openablei open the other vent
over the front door works for meWhen you need to drain off only an upstairs but have a great drain point downstairs, hang your hose in a tree/ garage roof etc.
Reply to Hints, tips & secrets of plumbing - No Banter please! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
