Discuss Hints, tips & secrets of plumbing - No Banter please! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Comprehension fittings are great, they know what you want to do when you want it done..
I solemnly agree..Shift+R improves the quality of this image. Shift+A improves the quality of all images on this page.
any pipe intended for gas needs a compression (if accessible) or end feed for the just in case i forget about it !!
Which is the reason for the small hole, debris stays out but you can't forget to remove it because it will fail the tightness test. Saves wasting an olive using a compression fitting just for pipe protection.
3 port valve, broken spring post, non changeable head, no time Tim drain etc?
Nuts n bolts. Job done.
If you're trying to bung a Fluidmaster bottom entry into a toilet and it is slightly catching on the side, it turns out that putting a small screw in the very top of the darth vader style helmet - and using it to lever it away from the side by couple of millimeters doesn't interfere with the operation at all, although it does displease The Emperor.
When commissioning connect p+ to gas valve and fga to flue and then u get inlet pressure on Anton fga printout. One of lads never seen it before...... Was sad when I heard how he did it.
When applying silicon sealant to a new bathroom, save hours of time cleaning down: -
1.) Apply silicon into joint, ensure joint is filled completely. Do not smooth down yet.
2.) Lightly spray a good quality silicon lubricant (like the WD40 silicon lubricant available from Screwfix) over the entire joint.
3.) Smooth joint off with your finger. No silicon will stick anywhere where silicon spray is.
Saves loads of time!
Soapy water does the same Crofty
Buy the silicone working tools set - ( the different shaped rubber bits that have tapered sides & different corner cut outs ). I never had any until recently & find them fantastic for shaping the silicone joint & removing any of the excess smear - often in one go. Only cost me about £4 in Lidl
Never tried it in a spray bottle to be honest. Have used it in a cup before but will give that a try. Cheers!
But the wD stops it sticking to tiles ect? Soap just lubricates face of silicone
faulty expansion vessel? not got a spare or time to go collect one, or cant do the job til next week......
drain upstairs, refill system bleed all rads apart from one(spare room, landing,bathroom) this unbled rad becomes your temperary expansion vessel.
you get to charge for the temp fix and again for the replacement!
now thats a top tip
I hear smoothing it with your finger can introduce mould to the seal
Reply to Hints, tips & secrets of plumbing - No Banter please! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
