Discuss Hive on Potterton Boiler in the Central Heating Forum area at PlumbersForums.net
Hi all.
So I have just moved into a new house with a Potterton boiler in it. Great big thing!! lol.
I want to fit a Hive to it but it obviously doesn't have a separate standard control box to just switch over like my last one owing to the internal timer etc.
Inside the main unit is the following strip... (see photo)
Can anyone point me in the right direction of what wires will go to what in the hive box? I'll run a cable back out of the boiler and mount it on the wall.
Thanks in advance guys and girls. :)
Right hand side yellow link wire ch r to 4 ch L to L neutral and earth left hand side to there corespondening neutral and earth etc
Need to leave the internal timer on hand / constant
Thank you. And I assume for the hot water will be the same: HW(R) ---> 3NO ?
When you say CH(L) to L, do you mean on the Boiler or the Hive? I haven't put a multimeter on it yet but assumed that the boiler CH(L) and HW(L) would be a switched live from the internal timer.
One last thing, would I be ok running the permanent Live and Neutral to the Hive unit from that Boiler rail in the picture? Or would you suggest a separate supply?
Thanks again,
you want to leave the hw on all the time with a pro max
ChL boiler side live on the hive
As above as that’s your live
Thanks agin for this. I'm so sorry, I've never had a boiler like this before. If you don't mind, why exactly do I want to have the HW on all the time? At the moment (according the old owner) its timed to come on once a day in the morning and holds it's heat all day. I just assumed I could use the Hive to boost it IF needed later on in the day.
You could do that and you would wire it in like the heating side but I would leave it on all day tbh
Hi. Thanks for your reply. No it's definitely a conventional boiler with a tank underneath and an expansion vessel at the top. However, will the internal timer on the boiler have any relevance if I remove the bridges from that rail and wire it to the Hive? I would have thought that the integral timer would call for heat, but it would be going to an empty choccy block no?
So am I right in thinking that it works as per my picture below? I like to understand how it works.
Also, if I want to connect the hot water to it, also, do I need to run the HW(L) to the Hive or will the constant live from the CH(L) suffice? I assume they're both constant lives from the same source.
Reply to Hive on Potterton Boiler in the Central Heating Forum area at PlumbersForums.net
Hi, I am trying to link a Hive heating & hot water dual channel receiver to an old Vaillant THERMOcompact VU GB 242/1 E system boiler. It has an...
My disabled daughter’s hot water has stopped working. It’s a relatively modern Potterton boiler with an indirect sealed hot water system and a...
Hi I’m looking to install the above. Atm I have an older one fitted (old wireless thermostat and old receiver that’s wired into my combi boiler...
Hi everyone, i was looking for advice on what hive I need to buy. my daughter bought a new build house and she want to switch the existing...
Hi I seek some advice on replacing an existing regular boiler. I currently have an old Potterton 10-16 Netaheat electronic, which is around 35...
