Discuss Holesaws sizes for stack? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
plumermicky
What sizes of holesaw bits is a plumber most likely to use? e.g for stack/cistern?
The best thing to do is just buy a set with loads of cutters so you don't come unstuck. However, most of these sets are cheap and nasty and struggle going through mdf let alone tresper panels! I have one of these sets for thin materials but also have several higher quality ones for common sizes. These being 18, 25, 36, 44, 55 and 120. I have found Starret or Bosch to be the best. Of course we are only talking about holesaws here, masonary bits are a whole new world!
If its for cuttinig hard tiles then you need diamond drills we sell a lot of 110mm to get stacks though Porcelain tiles.
http://www.*********.com/jpgs/125mm.jpg
Cuts out the tile for the loo pan
http://www.*********.com/bigholes/smaller/Dsc08202.jpg
Also good for extract fans etc.
Reply to Holesaws sizes for stack? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
