Discuss Honeywell ABV DU144 and DU145 in the Central Heating Forum area at PlumbersForums.net
John.g
Subscribed
Is there a reason for the apparent completely different settings on these.
For example if I require a flowrate of 480LPH at a pump head of 6M then I set the index on the DU144 to 0.5
But I cant see how this is achieved on the DU145, even if I set the index to 6, the minimum flow is almost 800LPH at a pump head of 6M??
Reply to Honeywell ABV DU144 and DU145 in the Central Heating Forum area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
