Discuss Honeywell and Danfoss Valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
HairyFool
Had a major refit of the CH system by a contractor, a bit annoyed because of the way it has been done. The electrician has completely ignored the wiring guide for the centre and done his own thing, makes it a bit of a pig to sort out so now wish I had done it myself.
Anyway, stupid question time. Saw this in my previous property and now find it here too. The two CH zone valves are Danfoss yet the Hot water is Honeywell
Having now seen it twice is there a particular reason for the mix?
Next, they bought a Danfoss pack including a contact cylinder stat. The RM cylinder is fully wrapped so has a probe port. Was there any other option other than using a different stat?
The cylinder will have been supplied with the Honeywell valve.
Is it an unvented cylinder? If so the stat supplied with the cylinder should be used as the Danfoss one isn't compliant with G3 of the building regs.
Reply to Honeywell and Danfoss Valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Guy's, Looking for some advice on an issue I have having with a recently installed thermostatic mixer shower in my ensuite. Everything was...
I need a little help if possible as I am trying to check that my current system is running efficiently but not really sure how to check, sorry if...
2K
Hi all. As the title says, I have a problem with an unvented cylinder I had installed last year where the first time I turn a hot tap on after the...
2K
A bit of history first. 2 yrs ago visited a grant boiler with boiler and pipework kettling. I added SentX200 noise reducer. It is standard open...
Hi there, I have a Danfoss HSA3 3-port mid position actuator/motorised valve that has failed a few weeks ago which was no big deal as I have just...
1K
