Discuss Honeywell evohome BDR91 problem in the Central Heating Forum area at PlumbersForums.net
peter challinor
Hello,
I have just installed the Evohome system hot water kit . I now have 2 x BDR91 relays.
One is commented to the electric supple to the gas boiler and the other controls the hot water valve.
I have 8 x HR92's all connected and communicating fine with the Evotouch Controller.
However I and having some issues with the BDR91 relays.
They are binding successfully to the controller but when the HR92 call for hot water the main boiler relay is not activating and when I carry out the RF check the red Led flashes on both relays.
I have deactivated the hot water and disconnected the hot water valve BDR91 in cast there was some interference between the relays but this made no difference.
The hot water bdr91 is about 40 cm from the boiler.
Even when the controller is right next to it the RF test fails.
I have reset and re-bound the relay numerous times and it binds successfully every time, but it is not activating and constantly fails the RF test.
I have reset the relays and swapped the face plates of both units without success.
It is unlikely both relays are faulty so it must be some interference or something!
Any help or suggestions to resolve this issue would be greatly appreciated!
Thanks.
Hi, I have the same issue.
I have unbinded and rebinded all of my HR92UK to the Evohome controller and also reseted the wireless relay BRD91A1000 (hold for 15 sec) the rebinded.
When I switch on any of the HR92UK radiator valves, the Evohome controller reflects this on the display but the wireless relay is not activated i.e. no green light.
Anyone had the same problem and managed to fix this?
Reply to Honeywell evohome BDR91 problem in the Central Heating Forum area at PlumbersForums.net
PSxxxxxx
