Discuss Honeywell ST 699 Programmer Unit malfunction in the Central Heating Forum area at PlumbersForums.net
I have an ST699 control unit on my central heating system (some 15 years old) which has developed a strange fault. After running normally, when the required room temperature is reached it cuts out as usual but immediately loses electrical power, with both the time display and the red lights going out. I have then to switch the power supply off and turn it on, whereupon the unit fires up. Once again, when it cuts out it loses power and I repeatedly have to go through the same procedure. Is this a known fault and, if so, can it be rectified or do I need to replace the unit?
If you have Googled ST699 problems, you will have seen many strange behaviours of these programmers when they get old. There is a backup battery inside to keep the clock going in the event of power failure, and that has a life of typically 10 years.
Your issue might be related to that, but I feel it's likely something else as well. The battery may need unsoldering and a new one soldering in, which may or may not help, so I would suggest a new programmer would be a much more certain and reliable fix.
Thanks for that. I presumed it's probably something to do with the age of the unit. I'll probably take your advice and replace the unit.
There's a table in post #4 in the above thread that shows how to transfer old to new connections, also a link in post #6 shows the wiring for each.
Reply to Honeywell ST 699 Programmer Unit malfunction in the Central Heating Forum area at PlumbersForums.net
It was fitted with the boiler a Potterton Suprima 30L about 21 years ago. Two PCB's later and a new fan the boiler is working perfectly. However...
1K
So I've used a wireless thermostat to activate my heating since installation, but it's just stopped working (Blank screen, no new battery's fixed...
2K
Hi guys, I have a fault on a clients heating system whereby the heating will stay on regardless of what the programmer is doing on its timed...
2K
Hello My trusty Vaillant 242 EH is having some issues. It has developed an issue when firing up the burner. The fault is seen with the hot water...
Hello, I hope someone can give some advice with this problem. I have a Vaillant ecoTec plus 418 with Drayton MA1 mid-position actuator, Drayton...
