- Messages
- 10,442
Had one the other day, their sparks had moved a socket into the garage for me to fit a washer as the custard wanted the utility ripped out to use as a store. Sparks said I could move them pipes for you whilst here. Custard said sound do it. I got called back to remove all the speed fit he had used and replace with copper as it was pi****g out with hot and cold pipes reversed.Usually happens when you poke the hot/cold through a wall and then go around the other side to connect up - massively overthink the “complex problem “...
