Discuss Hot Press Pipes Question in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi : I’ve no idea about plumbing so please be patient. The plethora of pipes in my hot press, which one is the cold water feed to my central heating system? I have an oil boiler in the garage. Thanks.
No idea, I'd have said 15mm pipe back left but looks like it stops (maybe at a bleed point)?
Pipes on left look like they feed a shower, pipe on right looks like cold feed to cylinder, pipes at back look like open vent, balanced cold and mains supply to tanks.
Center back could be it?
Best trace it down from F&E tank to be sure.
Reply to Hot Press Pipes Question in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
Sonya K
