Discuss Hot water but no heat Heatslave 18/25 in the Oil and Solid Fuel Forum area at PlumbersForums.net
We have a 9 yr old Heatslave 18/25 that's been regularly serviced. Heating was on in the morning but failed in the evening. My son is Gas safe engineer and suggested trying a few things before calling our usual engineer.
He disconnected the twin channel control panel and put in link's so it is always on. Took wire for thermostat out and put a link in. None of this started the heating. The diverter head was manually locked and this got the heating working. The lever returned to A when off. This was fine for a day but the same happened again. Does this mean the actuator head should be changed or is it the valve itself or something else altogether. I have contacted my usual engineer but he is on holiday.
Reply to Hot water but no heat Heatslave 18/25 in the Oil and Solid Fuel Forum area at PlumbersForums.net
Hi everyone, we have low hot water pressure in the entire house. It doesn’t appear to be a problem with the boiler. A Heatslave 25/32 External...
A
We have low hot water pressure in the entire house. Boiler is a Heatslave External 25/32, fuel in kerosene. The central heating is still working...
Abram R
A
Heatslave 18/25 not firing. No heating or hot water but no lockout light and diverter switch is locked in place. Hot water was scalding hot...
K
Hi, I have just had me diverter valve and cartridge replaced so solve my original issue of have both heating and hot water on at the same time...
Kyle Magee
K
