Discuss hot water cylinder control valve in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, I have an oil burner which is controlled via Tado to heat my home. My hot water cylinder is heated with water from the burner and also has a dumb immersion. I don’t use the immersion at all
And would like to replace it. The burner heats the water in my hot water cylinder with a TRV valve with a probe attached to the side of my boiler to control the flow of hot water.
In my head I would like to replace the TRV and fit an electrically controlled valve to turn the hot water flow on and off, do you supply a smart immersion replacement thermostat that could do so?
Reply to hot water cylinder control valve in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
