Discuss Hot Water Cylinder Stat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Had a new cylinder stat fitted. Flomasta thing
Open vented system, newish boiler, no problems with that or heating now after work done
Set at 65 as recommended
Hot water on at controller for over an hour this morning and from cold the cylinder only got to 25ish
Had it on since 6 tonight and stat only clicking off at 45ish yet boiler has been off for a while. Hot water from the taps and shower is bloody hot though!
Have I got a problem or is it just taking a while to heat?
Where on the cylinder is the stat located? If the water feels 'bloody hot' and the stat is detecting around 45 then something sounds wrong. Any chance of a photo?
I can't see it properly. They should be around a third of the way up from the bottom. If it is too low it will give you the problem you describe.
Fit it where I said and set it to 60 deg c.
Two things you can check:
1. Is the 3-port valve the correct way round? The ports are marked (on the brass body) A, B and AB. AB connects to the pump; A should go to the central heating; B should connect to the cylinder.
2. Is the cylinder stat wired correctly? Set programmer for just HW ON. The boiler should come on when the stat is turned up towards 90 and go off when turned down to 20. (The exact point will depend on water temperature.) If the opposite happens, i.e boiler stops when stat turned up and runs when turned down, the cylinder stat has been wired wrongly.
Reply to Hot Water Cylinder Stat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Later this year I am going away for a 2 week holiday and as the weather will be warm there is no need for the heating to be on and arguably no need for me to needlessly heat hot water. My intention was to turn the boiler off along with the mains water when going away. Now, I have heard...
