Discuss Hot water only works when more than one hot tap turned on in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Unfortunately due to forum rules, I'm not allowed to say. 1. to prevent you from attempting a repair yourself and 2. To prevent others reading this with a similar issue from also attempting a repair themselves.
Apologies if this is anally question but doesn't that rule kind of render this forum useless? If nobody is allowed to suggest what the answer to a problem might be for fear that they might try to fix it themselves then surely anybody that is not qualified should not be allowed on the forum as the answer to any question would always be the same. Ie get a qualified gas fitter to look at it.
That should say a silly question
Not at all. Anybody is welcome to join and ask their question however when it comes to questions involving gas then there are rules. These rules are in place to stop and protect people from attemping their own repair which is actually illegal in law. Sorry but that is the way it is.
The rule only applies to offering advice to gas related questions. This forum covers all aspects of plumbing.
Reply to Hot water only works when more than one hot tap turned on in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello All, I wonder if you can help me? I have intermittent hot water low flow from all taps in my 4 bedroom house upstairs and downstairs. I...
Milky hot water. Recently had a Viessmann 100-W combi boiler installed. Now when the hot water reaches any tap it is very 'milky'. This appears to...
I recently installed new hot and cold feeds to a new downstairs cloakroom. After refilling the system the hot taps were all dribbling, spluttering...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
Hi all Hope you can help We have a Gloworm Ultracom 38CXI combi boiler. During the Summer the taps and mixer shower run hot water consistently...
