Discuss Hot Water Pressure to bath & Showers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
rdo1104
My system is gravity fed and everything is in the loft (headers, cylinder etc.) I have just had a new 22mm feed fed to my new bath, a 22mm feed fed towards my first shower which reduces to 15mm prior to a salamander 1.5 bar pump, the 15mm pipes are then split to feed a second salamander 1.5 bar pump for shower 2.
Since having an upgrade to 22mm towards the showers the pressure flow in shower 1 is worse than before and temperature fluctuates which has never happened before. (Problem 1)
Problem 2 is that due to the tap in the new bathroom being a 15mm inlet fed ceramic disc type (not sure what I'm on about here but am quoting information from another source) this needs to be pressure fed.
So to summarise, what is the best approach if I started from scratch to feed 2 showers (negative head) and increase the pressure to the bath. It is not an option to change the tap at present so need to conside what pump options I have and if I need a Surrey Flange or similar fitting.
I know this is a long topic but hopefully we can break it down into stages. This is seriously beginning to damage my health
Thanks in advance - Rhys
why on earth are you running two pumps ?
and 22mm feeds reduced to 15mm supplying two pumps. not enough if you run both pumps at same time.
the way your going would be easyer to have an salamander esp pump that will supply the lot.
Cheers AJS - I was beginning to think that a single larger pressure pump is the way to go so would I be looking at a 3bar pump? and is it always necessary to fit a flange (surrey or Essex).
Second problem is the supply to the bath due to the type of tap which also needs a pump - do you have a view on which pump to go for and would this need a separate flange?
Many thanks
Rhys
have a look at the salamander pump site. give you some ideas.
i would use a esp pump to supply the whole lot.
use a surry flange or essex flange take the supply to pump inlet and pump outlet feeds showers, taps, baths etc
Reply to Hot Water Pressure to bath & Showers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are...
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
A
Hey, here goes and I hope it works.. never used one of these before! I have a Sagittarius Ergo mixer shower min bar of pressure required 1 bar...
