Discuss Hot water signal panels in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
A
AKSARAYLI
Hi all. My house have instant gas hot water system with solar hot water. Hot water is taking long time when I turn the tap on. The house is approximately 31 squares. I have been told the water is going up to the solar panels first and then going through the instant hot water system. Hence the delay. Is there an easy way to make water go through the instant hot water system without going through the solar panels? I am wasting so much water.
Reply to Hot water signal panels in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, Later this year I am going away for a 2 week holiday and as the weather will be warm there is no need for the heating to be on and arguably no need for me to needlessly heat hot water. My intention was to turn the boiler off along with the mains water when going away. Now, I have heard...
