Discuss Hot water supply - hair salon in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
mcniven
Been out to have a look at this one, all the property has is electricity and a cold water main. Hot water is required to feed two 'back wash' units. The idea of two independent electric showers is out of the picture because of the cosmetic design it would just not look too good. The salon kept trying to explain something to me that there is a company that offers 'salon boilers' - I purely assume these are storage cylinders with a fancy name. I do not know what the average hot water usage is for a hair salon. What would you fit in this situation? Personally, I think a small unvented hot water tank should suffice providing the water heating element comes on automatically as the temperature drops at a rate that will keep the water warm. I have never installed an instantaneous water heater - especially electric, do you get these with such a power output to potentially deal with 2 showers running at once?
The only salon boiler ive heard of was Susan just down the road.
Brought a whole new meaning to the phrase blow-dry :)
They look suspiciously like OSO unvented clyinders.
I've fitted a 'Salon Master' in a hairdressers before, it was identical to an unvented, just double the price.
What's the I comming like? Fit water softener make saloon products seem much better and they use less shampoo
Im not sure - it is 22mm cold main into property and to where the hot water source would be. I just dont know how much 2 backwash units would use, do you not think rather than paying 700+VAT for these salon based hot water units you could just install a 200-250 litre unvented cylinder?
Have they got the back wash units at the moment or can you get the technical details ??
They are spray mixer taps so don't use a great deal of hot, ask them what the peek usage is i.e. how many washes an hour at busy times they expect to get through & how long the water is on for during each wash ?
If all goes well with the business might they require more hot water ?
The amount of hot water can be calculated, at the end of the day it all about storage & recovery.
Reply to Hot water supply - hair salon in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied...
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that...
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
Hello, I am fitting new taps and a shower mixer in my en-suite and was looking to isolate the hot water pipes. I have an unvented indirect...
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
