Discuss House wall wet - prior plumbing work completed, potential leak? in the USA area at PlumbersForums.net
Hello all,
I hope you are well.
We have a question if we may regarding the outside wall of our house. We have noticed that the house has a wet look to the wall in a particular area. And while this may seem a little silly considering its winter in the UK and most house walls are wet this one looks particularly odd and we have had some plumbing work done here previously.
The ground underneath has a pipe that extends from our mains supply into the kitchen for our potable water source (non softened). Could the wet wall be indicative of an issue here? From my understanding the plumbers did have to drill from up underneath the DPC into the kitchen wall. Obviously, I am reluctant to lift up the ground below unless there is an issue, but the wall does look strangely wet considering the other walls are dry.
Thanks! :)
Looks like it’s coming from the window
I'd say you need to look higher up.
Possibly leaking guttering at high level dropping onto that window cill then running down the wall?
Or Overflow from toilet above or ?
Alternately the window cill looks to be twisted and angled towards the window, possibly rainwater pooling then over flowing
Reply to House wall wet - prior plumbing work completed, potential leak? in the USA area at PlumbersForums.net
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks...
