R
ryangas
how do u put your website link on your posts like halesowen
Discuss How close can a boiler flue be to a window? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Nobody has told you this, you have misunderstood ...it it always from the outside edge and if you don,t no this simple thing you could do with a refresh course.3 assesors have told me from the center of the flue thats why im a tad confused
are you saying that to measure the distance of the flue from the opening you put your tape at the window edge and take it to the end of the flue and measure that distance ?
if everyone is so sure could someone please tell me exactly what regs state word for word
sorry to go back to this guys but think about it if you measure from the center of the flue it makes no difference what the diameter of the flue is you are always measuring from the same point
as i understand it mi' over rule everything building regs get changed at long intervals new products get tested and approved dailyWhatever MI's say, they can't take precedence over building regs (in this case Part J Combustion appliances). It's no great surprise that MI's nearly always just reprint the relevant pages of the regs.
The pages below are taken from the latest issue of Part J. Note the horizontal distance of the flue opening from an opening window of 300mm - this is edge of opening to edge of flue.
See also Note 1:
"An opening here means an openable element such as a window, or a fixed opening such as an air vent. However, in addition, the outlet should not be any nearer than 150mm (fanned draught) or 300mm (natural draught) to an opening in the building fabric formed for the purpose of accommodating a built in element, such as a window frame"
Whatever the MI's say, they can't be less stringent than the building regs and as an installer making holes in buildings for flues, you must take account of the building regs in addition to any MI's. The regs are free to download - it's worth taking a look: Planning Portal - Part J (Heat producing appliances)
View attachment 4961View attachment 4962
looking through the IUP they state the following as the chain of command for info compliance
H&S at work act
GSI&UR
Building standards or regs
specific MI
relevant BS docs
other industry codes of practice etc
MI instructions over ride everything else.
I think you are wrong.. I have always been told MI over ride everything else and this is what we trained out at BGNope.
Just as previously written they don't overide H&S, GSI and building regs
Reply to How close can a boiler flue be to a window? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
