Discuss How do I remove the lever from a Mira silver shower? in the USA area at PlumbersForums.net
Hi, I need to adjust the max temperature on my Mira silver shower but am stuck at the first hurdle.
Can anyone tell me how to remove the temperature control level? I can’t see a screw to loosen but it won’t just pop off.
any advice appreciated.
thanks,
mark
I have the exact same situation, however I can't even see the grub screw at all?! There is a hole under the control lever but no matter what position I put the lever at the grub screw does not come in line with the hole so it seems I have no access to the screw at all?
Reply to How do I remove the lever from a Mira silver shower? in the USA area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The...
