Discuss How do I remove this dishwasher without flooding the kitchen? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Shall I turn the blue headed screw upwards or downwards, please?Turn of the blue plastic headed tap unscrew the blue water feed hose.
The grey flexible hose is the waste so remove from the white plastic pipe and you may need to re-angle that spigot upwards to avoid a leak or cap it
So in effect after the blue headed valve has been taken off, the hole must be plugged with the 3/4 cap seal. Sorry for being thick.When you turn the valve off and remove the hose , get. 3/4 cap and seal and put it on inplace of the pipe you have removed . ( same as the other valve )
If you are replacing the dishwasher straight away dont bother .
Thanks , read your earlier post again and found the answer for my question about the grey waste pipe.down but it will only turn one way as theres a stop
Many thanks. As always very good and helpful folks on this forum.see the grey nut with the bumps undo this and use this to cap it off
BSP Blank Nut Âľ x
Arctic Products Washing Machine Hose Washers Âľ" 5 Pack | Plumbing Washers | NoLinkingToThis
Reply to How do I remove this dishwasher without flooding the kitchen? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
