Discuss How do you wire a Google Nest to a Evinox 40-10E HIU (E-ON) in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello members,
Does anybody know how to wire a nest heat link to an Evinox HIU?
I know I need to replace the room module/thermostat with the nest controller and supply a 12v connection to the heat link. I also know to supply the heat link with a 240v connection for power from the HIU connection.
Looking at the instructions of the heat link I need to connect call-for-heat (Normally Open), common and satisfied (Normally Closed).
The problem I have is that unlike previous versions of the HIU my one has no obvious connections for the above. I have attached the electrical diagram to the HIU - can anyone decipher it at all?
I hoped I could simply use the wires that went to the thermostat, or would that be 'too easy' ?
Really hoping somebody has done this before.
Many thanks
Matt
Evinox Technical Diagram:
Room Module / Thermostat:
What happens when you link 3 and 4 ?
Hi Shaun,
Bit worried about touching cables to test stuff - are you expecting the heating to come on if I did that? and what is the chance this could break something?
Regards
Matt
Reply to How do you wire a Google Nest to a Evinox 40-10E HIU (E-ON) in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
