Discuss How long does it take to Commission a new boiler in the Gas Engineers Forum area at PlumbersForums.net
The boiler is installed, it just needs commissioning, I suppose when there are no faults because if there are then it is the same as asking how long is a piece of string?
The boiler is an Ideal Logic Max c35Kw, if that makes any difference.
Cheers
give us a bit more ! , why didnt the installer commission it ?
Sure - I posed the question badly....
What I meant is how long does it take to undertake the Benchmark Commissioning Checklist? If that is a daft question, them my apologies.
I want to know because the boss called me at 16:15 and said that the boiler would be up and running later that same day, but looking at thephotos, it seems that there was still quite a lot of work to do, including the commissioning. Safe to say, that the job ran over.
Actually, I can upload some photos, the first is what it looked like at 17:51 on the day of the install (some way off a finished job) and the remaining ones are what it looked like post commissioning on-hand over to the customer, bar the last one is what it looked like once they had returned and sealed the internal seal.- - following an AT RISK notice issued by the manufacturer.
And yes, the original flue terminal exit, was left open and exposed to the elements (it was the 24-25th January).
I normally allow for an afternoon for completing / filling in the paperwork , commissioning and filling / making good
They should make good the old flue hole, at least temporarily block it up until they can.
Didn't you say this was a listed building? I must say all that flue hanging in a residential won't and doesn't look great.
Reply to How long does it take to Commission a new boiler in the Gas Engineers Forum area at PlumbersForums.net
Good morning all, just a quick one here and i was wondering if someone could give a little advice on their own experience. I don't usually do a...
Not sure what my options are here. Basically a friend of mine recommended his father in law to do our plumbing/gas work for our renovation. First...
2K
Hello I’m hoping for some perceptive / input as I’m a long-distance landlord trying to unpick the best thing to do. Gas safety certificate was...
Just fitted a new boiler for customer have gone to gas rate when commissioning and batteries are dead in gas meter. Gas supplier won’t come out...
1K
Had a quote for a new boiler installation. Quote said... Power Flush require and install new boiler, ==== After the boiler was started, it was...
